i was thinking oil seepage is a common problem among most e90. so if the dealer can fix it for me or give me a discount i dont mind, problem is i dunno exactly how much. plus the absorbers, and brakes... hahha. but just to check, are these common problems faced by most e90s, or only this one in particular. thanks
xiaofoggy;907854 said:
bros i need some help here. appreciate and thanks in advance before going on. going for my bmw 320 prefl (2006, milege 118000km, quoted price at 10000/yr depreciation) and here's the AA evaluation report. Please advise on how much needed for repair and if its wise to proceed with purchase.
1. please check engine coolant content
2. engine oil sump joint, oil sump sensor, flywheel area seepage.
RHS engine block and water pump area dumped with oil.
3. rear rhs shock absorber oil seepage
4. rear both shock absorber bump stop torn
5. all 4 brake discs worn
Yes agree. high mileage and also lots of things to change. there are many units in the market. the price may be cheap because of all these but it will cost you more time and money to remedy them. And due to mileage, more things to change potentially...
dude, the car looks like it has been driven hard and not maintained.
walk away and look for something better.
not worth the trouble and cost. unless you are prepared to spend more than $10k upfront to solve all these issues - change all brake discs, all shock absorbers, solve engine oil leak issues, etc.
which also means that your depreciation will increase to > $12k/yr.
Bro,
05-06 320i (aka e90) will have all the wear and tie items, oil leakage first, then water leakage, then aircon coil/radiator problems, worse is engine or transmission problems.
If the dealer or previous owner can't provide all the servicing records, it usually means the car is not serviced, and you can expect a min 5k bill just to get all the wear and tear up to running condition (this exclude engine/tranny problems).
Also, AA report is useless as E90 has specific problems to look out for, best to get BMW specialist (Munich Auto, BVO, r2d) to do proper evaluation, then re-negotiate price with dealer and do repairs yourself.
Better yet buy a newer LCI e90 with less mileage, or 323/325i less problems. e90 reach 100k all the wear and tie problems will surface. Hope this helps.
Low mileage cars also headache, as the PML svc interval in 06-09 if i am not mistaken was 25k.
Most cars that was serviced once a year, or even longer interval (meaning oil was not changed) will have sludge problems in this climate.
Best is to open engine valve cover to check the engine internals so see if it's sludged up or not, through a competent BMW workshop.
Aiyoh! Stick to main areas, and don't travel at night.... I go in almost weekly for makan and petrol... so far so good. Always stick to the more crowded and prominent petrol stations... Don't go to ulu ulu ones!
canuck78;907538 said:
Hey bro lkm,
You forgot most of the car jacking, robberies at knife or gun points all done at petrol kiosks haha?
whether main areas or ulu ones, be vigilant. Things will still happen, just a probability kinda thing. ultimately, there will be risks that we all need to take and dangerous places we all need to go sometimes. Just try to decrease the frequency so the probability is lesser. What else can we do since life is not perfect I guess =)
Just done my oil leak problem with Francis. One day job. Happy with his service and now monitoring for the next few weeks whether need to top up EO ~
Saw 3 SG car in the workshop.. 1 white 3 series doing engine overhaul.. Seems like a lot of cars heading up to repair their rides..
with $80k-$90k coe ...
a few $k to overhaul car seems sup sup water liao
and $2000 sgd = $5000 myr :thumbsup:
Bro, how come you know the market rate so very well hehe
In SG it's 5k to overhaul huh. PML or MA even more $$$
Bro, what is the cost of the brake pad, rotor n sensor fr eng soon like?
hi bro!
can PM me Francis contact/address?
but if im not too sure what is wrong with my BMW, how shld i go abt buying the parts from eng soon before gg to his workshop?
thanks!
lim_ck;851717 said:
i'm not sure what oil PML uses for servicing. it just says LUB9000 in the invoice. But i bought this 5W-40 oil for my latest service at PML. at $16 per litre it's half price of what PML charges for their oil.
Hi Lim CK, where you buy this engine oil? eng soon??
DayDreaming;876410 said:
U did top overhaul?
Hi Day dreamimg, the gasket in the last picture is item 1 Valve cover gasket ? This gasket is where the engine block is ? (after the BMW Plastic cover is taken out rite??)
I m not very sure abt this wo..
Eng Soon has got this at $16 + gst, 5w40 BMW oil, using this in my e90, quite ok so far.
Just did my overhaul last week, will be posting some pics soon.
Is yours white 320 has been there quite few days for overhaul? keke.. nice facelift LCI headlight..and serbring exos.. keke..
i was there changing to LCI halogen headlight and rear absorber too.. Saw another black e90 320 sitting outside the shop.
Pm me how much the cost and what is the job included for your engine overhaul.. thx
Need to go for my servicing soon. Any bros or sis care to share which engine oil are u using and where to buy? My ride is a PFL E90 320. Thanks in advance!
