G30 owners please fall in!
Hi All,
Friends and Fans of the BMW G30:[/I]
4. mark 1919 - 530i lux black
5. F10fan - 530i lux black
6. Fres - 530i lux bluestone
11. CY Wong - 530i lux jatoba
21. Sen Min - 530i m sport White
23. Daniel Golfer - 530i m sport Mediterranean Blue
24.Twinnie - 530i m sport Carbon Black
25.Michaelsia - 530i Cashmere Silver
26.REND - 530i Carbon Black
27.Schnider77 - 530i m sport Bluestone
28.TezzaRed-523i Tasman Green (F10)
29.Raptor77-540i m sport sophisto grey
30.lawrence h - 530i m sport bluestone
31. CZJ1516- 530i m sport sophisto grey
32. Eagle1 - 530i Sapphire Black
33. Ricardos - 530i Lux Mineral White
34. Jackpooi -530i Carbon Black
35. angkk - 530i m sport -
36. FrankieLim - 520D white
37. Mango3 - 530i lux mineral white
38. Delrosa81 - 540i M Sport Sapphire Black (Updated my model change)
Hello guys! I'm a new G30 owner. I prefer to use the waze map than the default loaded map so I went to try the screen mirroring (via my samsung) but the the projected image is so small. Can anyone guide me to make it full screen?
Im on aftermarket 20s with
8.5J(ET29) and 9.5J(ET27)
CB 66.5 PCD 5x112
OEM size is
8J(ET30) and 9J(ET44)
hi lim ! thanks for your reply to my question! but if i wana stay at 18inch or 19 inch. will i still b able to do staggered? and oso i m interested in 1 particular rim actually which is BBS LM 19 inch. its pcd i think is 5 x112 offset 38. do you think can fit or i need to use spacer?
Im assuming that these are for the rear?If these are BBS,then it should be 10.5J for the rear?For the front,u shd aim for ET in the low 30s or high 20s with width not more than 9J.Im refering to 19"
It should be able to fit but note that 275 rubber may not be able to strech to 10.5J wheel.Do u plan to resuse your old tyres?
I believe should not cause any rubbing.This also assumes that u do not lower the car. Original wheel for the rear is 9J with offset of 44.Thats a diff of 44-38=6mm,moving further out,closer to yr fender.i do not think the width of the wheel will play a difference.
I have limited knowledge and u should take it as supporting info as its is only based on what i read online in forums,from the posts by a member who goes by the nickname remmib on bimmerpost. U can also check his posts out.
In that sense, suggest u also confirm with a tyre shop.
But from what i understand,BBS for VAG is not able to fit?becoz of the center bore size. Whats the center bore for LM?
sigh... not sure of it. perhaps i will bring the rim dwn to tyre shop n check. earlier i ask leong seng abt it but they not reali keen to tell me cos i guess i not getting any rims from them haha.
I heard of a few getting from hurry tyres. How about giving them a try?
That’s the bro I know! Totally back...cheers!
Hi All,
G30 SG is having a meet up on below date, forum G30 owners that are not in the chat group are welcome to join us.
Please add your name to the list if you are interested. Thanks
G30 Meetup 13-4-2018
Time: 8.30PM
1)
2)
3)
4)
