detach8;671411 said:no lah.. mechanically...
change the diff lor. to one from a different car, e.g. 325i or 320i manual.
i just dunno the ratio now. but it is known a taller diff will
1) increase pickup but
2) decrease top speed
3) reduce fc
detach8;765684 said:Quick bump on this topic. Anybody knows if there's a diff replacement for 320i?
davidtch;765710 said:Change to F30 320 will solve all problem.
wt_know;765714 said:at least 328i la ... smelly smelly 350Nm torque![]()
Meldon;765956 said:I cant believe it when I saw that the new 328i have an output of 245BHP/350NM with it's 4-cylinders twin turbo 328i.
0 ~ 100 in 6.1s, just 0.6 secs under the new 335i![]()
ed6141;765717 said:Hopefully, 320d will be a viable option in the near futur. 380Nm Of torque, no horse run.
Pickup confirm poon-pee-pee.![]()
I can't find 320 but found this link:detach8;765684 said:Quick bump on this topic. Anybody knows if there's a diff replacement for 320i?
ECU re-map only increase 5 - 10hp which nothing as compared to the body weight.TohTo;766171 said:Then do a ECU re-map.![]()
davidtch;766194 said:I can't find 320 but found this link:
BMW Gear Ratios
