Overhaul Transmission - Sep 2006 E90 320 PFL
Re: Overhaul Transmission - Sep 2006 E90 320 PFL
Bro pengful , can pm me the workshop contacts and damage too? Thxs!
please PM me the contacts also. just in case.
plus pricing too.
thanks alot in advance
Bro pengful ,
can u pm me the workshop contacts and damage too?
Thanks!!
Me too thanks bro
Bro, need contact and damage as I have the same problem as u. Thanks.
Hey guys, only just saw this post. I had the jerk before stop problem before, was recommended by a fellow forum-er to go to BVO. Half an hr job and $80 to reprogram the gearbox. Had been a year already, braking is still smooth, no more jerks and gear change is smoother too. Not sure of the extent of your gear problems, but you may want to try BVO too, in case your problem is the same as mine, just need some reprogramming the gearbox.
Hi guys do you guys know how much to replace the parts "auto filter"? one of gearbox parts~
and what's the function of it?
thanks
My opinion is, if transmission needs to be overhauled, you might want to consider changing your car as it will never be the same car again. I mean, its like a major by-pass surgery, your recovery depends on the skill of the surgeon...
gearbox up lorry, pml quoted 9k plus and another 850 for workmanship for replacing the entire gearbox. CB
Well I spent about $50-60 buying a diagnostic cable that allows me to reset transmission adaptations. I did the full reset including torque converter and thought that was a good deal because i can now reset again and again and again and again. But alas I sold my old ride so I can't comment if the reset fixed everything.
i just changed to a recon transmission paid about 5k everything in.
bimmer trans has short lifespan of around 120k... is it worth to get recon unit?
my mileage is super low almost 7 yr less than 100k
You need to change the whole GB?
I thought normally only the mechantronic/solenoid faulty only.
yes that solenoid alone is about 3k plus so i opt to change the whole thing
thanks
I had the jerk-before-stop problem for the longest time. Can't remember when it started but my JOY did not last long after the warranty expired.
I had the ATF flushed and filter changed recently. Filter cost 200+. Everything runs smoother now with the jerk much less pronounced. Not sure if they reset the gearbox. If it comes back, I'll try BVO as another forumer suggested.
Gb valve body just up lorry today. Quoted 3k plus labour by Top Speed for replacement. Great...
