Throttle issue.
Re: Throttle issue.
i just hope like what he said my three problems are linked...1) throttle loss during moveoff...2) intermittent loud rattling sound from engine during acceleration...3) ultra high fuel.consumption
Re: Throttle issue.
i found just the right word to.describe the clunk.clunk sound from my engine when.i accelerate. It sounds like "marbles in a can"。This is exactly when I heard...damned loud from the outside.
Re: Throttle issue.
The tentioner is in the middle of the chains and will expand and contract at given times depending on what the vanos is doing.If the vanos is retarding the cams the chains will become loose and rattle against the bottom of the casing.The tentioner expands in the middle to expand the chains from scraping.
Re: Throttle issue.
I have this sound as well when I accelerate. I have asked around but never seem to get an answer for it . One of the workshop even mentioned something along the line of hydraulic lifters . Anyway like you mentioned from the other forums it seem to have to do with the vanos.
Re: Throttle issue.
In addition to the rattling sound coming from the upper valve train assembly, you may experience CEL, engine codes, and I've heard from one source that your gas mileage can start to decrease. The source who told me this said their gas mileage went all the way to 7mpg before it failed. You may also experience white smoke from the tail pipes as the VANOS system continues to break down.
Solenoids: It is possible that you have a bad Exhaust Solenoids. There aren't as many cases of people experiencing the knocking, you would typically have a CEL light, but there are some instances in the N54 that the knocking occurred. The replacement of this part is much cheaper than replacing the entire VANOS system.
Re: Throttle issue.
the ws uncle mentioned there a need for special tools to work on the "Banos" and he have the tools....seems like he knows what he is doing
BMW's solution when VANOS units fail is to remove the entire VANOS unit and replace it with a new one). VANOS repair may require special tools (cooling fan clutch wrenches, etc.) that can be rented or purchased from a variety of vendors.
Re: Throttle issue.
bro the marbles in the can sound you have is all the time or only once a while.
Re: Throttle issue.
From this website doesnt seem that hard to replace the solenoids. But I never had the tools to do it. Let me get some codes before commiting the repair .
Re: Throttle issue.
You never gun the ride so error never show up ?
If your mech going to take the intake solenoid out ....... Maybe ask him to take out the exhaust one along the way to check ?
Hope your problem will be addressed in the next couple of days ........
Thhmarc;1059946 said:
mr RBB, this is the code i saw on the reader....2A82. Real.funny thing is, the symptoms are not there when I drove from Hougang to Tampinies this morning. It happened the whole time yesterday.
Re: Throttle issue.
Lets say if i put the window down and at times accelerate harder , I will hear it most of the time .
Re: Throttle issue.
bro how is your fuel.consumption and is there any throttle loss during move off?
Re: Throttle issue.
Yes I have loss of power . Again I m on powerbox for n52 so maybe its the way it drives with the PB on . I m talking bout almost stopping then trying to accelerate again ,it feels like there is nothing coming out for that 1 second.
The FC I stopped monitoring long time ago , bcoz it was crap to begin with . Mine is probably bout 8 ? Maybe less .
Re: Throttle issue.
i am getting more convinced by the workshop uncle words about that timing adjustment. I think the timing he mentioned should be the camshaft timing. I have check that my head gasket was repaired before and thus from the article below, maybe the the timing was not adjusted proper.
If you replace your head gasket, you will need to retime your camshafts and re-install the Vanos unit. For the purpose of instruction here, we'll assume that you have your cylinder head installed on the engine block, the crankshaft is locked at Top Dead Center (TDC), and your two camshafts are locked using the BMW camshaft locking tool. This article will guide you through the process of retiming your camshafts, and re-installing the Vanos variable camshaft timing unit.
Re: Throttle issue.
Bro, i jus had my head casket, alternator pulley, fuel separator change... didnt see ws do anything to the camshaft or vanos..
Re: Throttle issue.
Only if the WS need to take the vanos out then the setting tool is needed so that the camshaft timing isn't lost. Head gasket replacement will affect not timing. Have those solenoids checked out first ......
Re: Throttle issue.
tats funny the readout mentioned" if you replace your head gasket, you will need to retime your camshafts and re-install the Vanos unit"....are you sure vanos need not.be removed?
Re: Throttle issue.
Does it sound like the diesel taxi's clatter when they accelerate?
BMW 4 cyl has the same sound, as was in mine when i first got the car.
Esp during startup is that engine oil can't reach the hydraulic lifters which is at the top of the engine.
So the solution to try for this maybe in cheapest to most ex cost i.e.:
1) buy hydraulic lifter oils to add in (1 can of liquidmoly from autobacs around $20+)
2) try a thicker engine oil e.g. 40w
3) desludge your engine (if you engine is sludged up, mostly 05-06 cars by now probably could be)
Re: Throttle issue.
If the WS knows what they are doing, they will "lock" the camshaft position before removing it e.g. with cable ties etc.
Re: Throttle issue.
I am not sure now.... what will be the symptoms if the camshaft timing is out.
taisunwincasa
