Volker Racing Spark Plugs
Re: Volker Racing Spark Plugs
Hello everyone.
I think it is time to clear the air. In an earlier post by Calvin, the post lifted from another forum was by yet another friend trying to help out. Since then, the prices for the plugs have gone up as the new construction methods and materials have increased the manufacturing costs. Rodney has posted the right prices and models for the new batch of plugs and these are prices meant only for forumers only.
Looking forward to your continued support.
Regards
No worries CP. There was already a post earlier on (one of these 30 pages keke) by Yendor/Rodney on the price increase from $135 to $150. Non-issue for me. I must say again the plugs are wonderful!
Hi yendor......after I install the "Super" plug.....I'm a happy man....
So yesterday went dwn to bvo to install the UUC pulley kit + KNN air filter. But after that, I don't feel the any improvement on my car, but start to feel a bit heavy than b4.........
So this morning I went dwn to bvo again, and replace back my stock pulley. Now I get back the feel of when i just install the plug.
Just wonder y????? Is it good to have the UUC pulley back to my car....or not?????
Hi Yendor....what model of volker plugs suit my E46 318 (1.9L/4 cyl)? Price?
With the UUC pulleys, the car would feel lighter coz the pulleys are supposedly to be lighter than stocks. Regarding the air filter..not sure though...
One word.... Strange. With the pulley, the only downside is your steering might feel a tad heavier. Throttle shd be lighter.....
Bro, the UUC pulleys are actually heavier than the original plastic ones. The pulleys reduce the running resistance by reducing the rotational torque needed to drive the power steering and water pump. Thus at the same engine speed, your ancilliares (less alternator) turns at a slightly lower speed (about 10% slower).
The car should be able to achieve slightly better engine response with the pullies. Before i go on further, was your clutch fan coming on a little more often with the pullies? Sometimes when you install pullies, the coolant flow is not enough to get rid of the excess heat and the temps rise causing the fan clutch to engage and driving the fan. When the fan comes on, it is gonna be a major drag on the engine. This may explain the lag.
Let me know dude....
Bro, I think you should go for the 6ZX plugs cos yours is the 8 valve engine right? If it is yours will cost $90.
Mr Beem. CP will be heading up to KL the following week......
Hi!
Do you mean the UUC pulleys have smaller overall diameter? Not a great idea; the water pump will be under-driven (spin at a lower speed) that may affect the cooling rate...almost like a slipping belt! Dont really see the benefits of the pulley except that it lessens the load on the engine...for the rite or wrong reason??
Ciao
Thanks for the info yendor..........by the way...how do we check the clutch fan coming on more often with the pulley?????
Heheee....coz i dun know much abt the car syytem/engine.....
The pullies are actually larger compared to the stock. The system uses the same crank pully (so harmonic balancers are not affected) and are installed on the power steering pump and water pump pulleys) that is how they underdrive is achieved. UUC did a study and the 10% underdrive was acceptable. I usually compensate with a bottle of water wetter or purple ice to increase heat transfer.
So far my temps are constant before and after the pullies.....
yendor,
Great if someone is going to KL..u mean on the week of 15 Sept?
Bro you can hear the fan spooling up if your radio is not too loud. It sounds like a loud "whooooo" and it usually comes on after some stop start traffic. Just use your ears and it should be quite obvious.
beem said:
yendor,
Bro will let you know.
Guys, latest update on status, these are the guys left from the original order.
1. Jaskin 4 pcs
4. Rex7_vtec 6 pcs
5. Silver 31 6 pcs (7ZC not in stock yet)
Rodney
Hello Rodney,
Many thanks for your wonder plugs. Car feel lighter now.
My brother is driving a M3....oops.. not BMW M3 but Madza 3. Is the plugs suitable?
Regards,
black_cat said:
Hello Rodney,
Regards,
Bro. Mazda 3 uses the 6ZX plugs. they are $90 per set of 4 plugs. There are lots of stocks now.
beem said:
yendor,
Bro, you've got PM. Will be heading up to KL over this coming weekend.
