Which engine oil do you prefer
Re: Which engine oil do you prefer
Wh0cArEs;630262 said:
dat is correct!
and u need abt 7L for the E93 335i
Thanks for your info,if HKS comes in gallon then 2 tin will left abt 500ml if comes in 4l per tin then 8l-7l=1 litre must store in a glass bottle liao.
Pass by TRD motorsports at autocare,saw this Tom's 5w40 $210/4l.
The owner told me its for turbo cars.
Though i only tried TRD engine oil for NA few yrs ago,i guess this Toms should be gd cos its very very ex!
I know my answer from u guys is not worth($368-420 each oil change) but sometime must try something new:p
haha just bcoz it's ex, doesn't make it gd :)
Give up the idea for using high grade or exp engine oil liao.
Will use mobil 1 gold,liquid molly or those price ard $80+ /4l.
Engine oil cooler coming soon..
bimmerjoe;584904 said:
Anyone using Caltex's Halvoline 5W-40 from our local Caltex station? Very little mention of this oil. It's slightly cheaper at S$99.50 as compare to Mobile 1 at S$115.55.
You can get Mobil 1 5W40 in Giant for less than $50/4litres..if you need 0w40, you can get from MX trading or Carfefour for less than $14 per litre...
Hi guys
Can E60 520 run on 5W40 engine oil?
Require your kind advise please.
Can advise the est price for torco racing oil? pm me pls.. thks..
Amsoil 5W40! European Car Formula!! So far so good for me! Buy own filter - original BMW, then change in JB for RM30! Servicing on the cheep!
How come you gave up using high grade engine oil ?
I'm going to install engine oil cooler next month@boss.
Do i still need to use high grade engine oil?
Normal grade(mobil gold) can afford to change at 5k km or depends on mood,if i use high grade it must last me for 10k.
Although i will have cooler but there's still chances of topping up 1 litre engine oil warning before next oil change.At 5k the chances should be 50% lower or none(normally happens after 8k on my ex E60).
What's the recommended BMW spec for N54 engine oil?
Mobil 0W30?
Hello ppl, I'm very new with engine oil thus I need help with it.
1. Is Mobil 1 5w30EP good enough for Z4 e89 is running on a N52 engine
2. Can my ride use Mobil 1 15W50EP?
3. What is the diff with Mobil 1 5w30EP and 15W50EP?
Thank you in advance! :)
Hi Seniors,
Newbie here... for a 3.5yrs old E90 320i, what engine oil is recommended?
wrx2.0;636902 said:
Hi Seniors,
So far tried Torco, Motul & Liqui Moly. I think I like Torco best. Weight wise follow what your car manual recommend.
Mobil 0W30?
Manual states 30 weighted oil. Brand wise, manual doesnt state but the engine oil bottle shld state if it meets BMW standards.
