topprize123
Re: Case of My E90 (320i) Disappearing Oil - 1 liter every 2000++km!!
hi Guys;
Just share my experience, I have oil leak problem too, fixed one place and another place leak again. Done all the fixes on external leaking and still my engine consumed oil every one month of my normal routine drive. I used to go to a famous BMWS in Alex and they don't really offer good service decided to switch to one at level 2 AMK Autopoint.
The WS owner Mr. Lim told me that 10 out of 10 cars got this problem (mine is E60 520) of oil consumption problem around 100k mileage. Decided to bite the bullet and give it a try to do a top overhaul today. His advise is not to switch to thinker oil as it may damage the engine in the long run. I think if I do it right the first time with the right WS when I encountered oil leakage, I could have saved a lot of money.
hi Guys;
ozipo;1044613 said:Should not rush into changing valves just because someone else describe
same symptom as yours
Better to get ws to trouble shoot than to self-prescribe the fix
Most likely reasons how oil consumption varies:
1.Even when new, some engines will consume more oil than others.
In passenger cars, an oil use of 0.1-0.3% of the fuel consumption is seen as normal.
Even within the same series of engines, variations are present and about 20% of
the engines have a higher or lower oil consumption than average.
2.A long list of mechanical problems may lead to oil being used up,
such as wear and damage of seals and gasket, the bearings, cylinders,
ring grooves, connecting rods, etc.
3.Driving style has a huge impact on oil consumption.
Frequent acceleration and driving at high RPM will inevitably
increase both oil and fuel consumption.
4.Failure to respect the oil drain interval will lead to oil being used up faster.
Dirty oil will block the thin oil passages and some oil will remain trapped there,
instead of flowing back to the sump.
5.Inappropriate viscosity grade: too thin oils with lower than recommended
viscosity will tend to enter the combustion chamber easier and get burnt
together with the fuel.
6.Similar to a lower-than needed oil viscosity, too high engine temperature
will also result in thinner oil and increased consumption due to burning.
