GB: iPod/iPhone Y-Cable for BMW
Re: GB: iPod/iPhone Y-Cable for BMW
Deadkookaburra;513326 said:
just note if you are connecting Ipod car charger together this jack, you will need to buy the proprietary AUX jack (skinny rubber head). Most aftermarket ones are quite thick therefore both cannot be plugged into the Ipod same time.
i filed 1 side of the AUD Jack flat to accommodate both. :nehnehhh:
How about Griffin Autopilot?
Griffin Technology: AutoPilot - Charge/control/play your iPod through your car's AUX-in port
Griffin Autopilot has an aux out. So, can use 3.5" jack on both end.
C3P0;513530 said:
I am told by PML that the y-cable cannot be used for charging 3GS iPhone, only can charge 3G iPhone and ipod.
But the other function works fine.
Anyone can verify? If confirm, then I don't know wat cable to buy liao, sian....
Hi robot, if u see page 3 for a post by SEI, it tells u that the ycable cannot charge 3GS iPhone already. Hope this is useful.
er... y u quoting yourself?
u guys need me to take pic of the cable charging my 3Gs?
Er...because I found SEI's post after I posted my question. So I honest and answer myself ke ke. Paiseh, robot CPU a bit cuckoo liao.
Btw just to confirm: u are using PML $170 tok price ycable? I presume ur car has 2 holes under amrest, one is USB one is round head Jack (otherwise u won't be buying ycable alamak what am I asking.) ?
robot better go do a fw upgrade :D
yes, its tat cable, but im from msia, i bought it at auto bavaria for rm 380
Malaysia boleh, singapore cable da boleh!
Joking la, later I ask them for a cable I will test it out.
Sharp, just to check:
1) Your ycable is the one with part number ending with 812?
2) Confirm u are using iPhone 3GS; and
3) Which month is your car manufactured?
Your answer may be able to help me confirm why my ycable doesn't work. I know it's partly due to the FireWire/USB charging issue but I can't figure out why it works for some people but not for others....
61120440812, my part number
yes, 3Gs
manufacture shud be early 09
it charges dem slow though
yes, 3Gs
Thanks bro. U indeed has the latest phone and cable.
I suspect why yours is working is because BMW has done something to the 2009's car so that they can take the new 3gs USB charging.... Mine probably wasn't working because the car was manufactured in 2008 and BMW probably hasn't done anything to the car yet. Not very sure, just my theory....
Both Scosche (which I use) and Griffin sell adaptors that can connect into dock connectors that will previously not charge iPhones (such as my previous Alpine HU and current E81 ipod connector) and allow for charging. (It still won't play on the e81 business radio but at least solves a charging problem, say if you need to run a power consuming app such as Sygic navigation, etc.)
sharps;514673 said:
har... sure boh...
u try liao kenot charge ar?
Yes try liao. Out of 20 times I plugged in, it charged successfully for....2 times :slaphead:
sharps;514691 said:
means can charge la? :p
Yes, though very slow.
Just now I succeeded again - 3rd success since I bought it 5 days ago.
Today must buy 4D, I'm in luck.
aiyoh, like that means can charge la, wait a while i guess
but super slow, better than nothing
Which brand did you buy?
it's from PML, BMW part. The part number ends with "812". Do u have the same cable and charging problem too?
Is someone selling off their cable?
Need one to fix in my wife's Lexus GS300.
