dleo;559620 said:Is it advisable to buy extended warranty from workshops such as Khang Auto (http://www.warranty.com.sg)?
zorro;559600 said:Some people will try to flush those ATF in the torque converter by running the engine/gearbox i.e the old oil in the torque converter will mix with the rest and drain again so will take another 3-4 litres...Your case is just renewing the ATF in the sump only...How much is your filter and gasket cost? BTW you can return the unopened bottle of ATF or exchange with other parts if you got them from Eng Soon.
wt_know;559666 said:flush is obviously better.
old oil mix with new oil = 1/3 old already huh
zorro;559669 said:Our gearbox cannot flushed using the machine unlike the E39.. There is no place fill the ATF or check the ATF level from the top unlike E39 or Jap car.
They have to pump the ATF into a hole at the lower bottom of the gear-box until the oil flow out ..
