Hi everyone, anyone kind to PM me the workshop address in Permas Jaya?
Many thanks and do they open over the weekends?
Hi bros,
Can PM me address and contacts for Francis's workshop and 1KM's recommended workshop?
Thanks.
Jayll
PM's sent! Wah.... looks like I gotta stop giving out workshop address.... else they will be too busy to fix my car the next time I need them liao... LOL!
I think so too, the volume goes up, quality starts to drop? Haha
Open Sat from 9am, closed on Sun.
For those with White smoke caused by leaking oil seals, typical part required to fix include:(w/o labour of course)
1) S$22.00 - Oil Sump Gasket X 01 PN:11137511224
2)S$ 20.00 - Flywheel Oil Seal X 01 PN:11117511396
3)S$2.00 x 16 pces (S$32.00) - Value Seal X 16 Pces PN:11347505417
4) S$12.00 - Torque Converter Seal PN:24317519352
Grand total Parts Cost: S$92.02 (GST Included) - Eng Soon PL
Hope above help.....
Hey bro Do you mind pm-ing me the workshop add?
I have a lots of things to be replaced in my ride!
Thanks a Million!
Thanks a Million!
You got Pmed...
I'm wondering whether to buy a E90... any gurus can advise is engine oil leaking frequent?
The answers are very obvious im this thread, iebmw 3 series thread, under oil consumption / engine oil leaks etc
This must be the most heavily discussed thread in 3-series
Most if not all 320i using IL-4 cyl engine will have engine oil leaks between the 4-5 yo mark, due to engine seals type and wear and tear in our climate
Not sure about 323/325i which is 6 cyl, but hearsay less prone! If you buy bmw, prepare to pay lots more for servicing and maintenance esp a used one. The alternative is to buy a brand new or one still with warranty from PML
U r right...I hope to have more than enough moola to get a brand new one
Derrrick Yap;706968 said:
Seem all Beamers have leaking problems and high rate for wear and tear. I sort of begin to dislike having to keep up with all these hassle and most likely will revert to Jap model for the next change. Perhap the IS 250 will fair better.
Same sentiment.....
Last nite my car ask me to top up engine oil but this morning resume normal.
So should i top up or not? Could it be the oil sensor?
My mechanic told me the only way to verify is to drain the oil out to check whether the amount of oil still there, is that true?
My 06 E90 is having a bad leak. Top up almost 1 liter every 2 weeks. Went to local workshop but can't fixed the leak completely.
Thanks to lkm, who share the JB workshop.
Its a nice little shop with very helpful boss the staffs, very detail check and reasonable pricing.
Changed 5 seals and 2 pipe on the engine. Now left with gearbox and flywheel which also detected with oil leaking
Could be the oil sensor. I had mine replaced around the 5-yr mark...
Been there, done that... you are in good hands as they are a competent workshop and value for money.
I'm there right now, using their wifi to log in... fixing up the flywheel amd gearbox
I believe when the gasket is replaced but where the gasket would sit is not properly cleaned,it will result in problems.
canuck78;922245 said:
Some sludge at the oil cap is normal as the bimmer engine runs pretty hot, and with condensation, this is the normal place for some sludge to gather. But purely from the oil cap, even if you shine a light inside, most of the view is blocked so you can't really see whether the valvetrain / cylinder head is sludged up.
I can live with some levels of light sludge in the engine, but not the heavy levels I had in mine earlier. Whilst my was not the worse i saw, which already bothered me for quite some time, it's the fear that I know block oil passages can result in low oil pressure and worse case, for the engine to seize (aka car "heart attack").
The only effective way to tell whether your engine is sludged up or not, is either to open the engine valve cover, or drop the oil pan below.
Given you have changed your valve cover gasket 8 months ago, i don't think you need to replace it again as this gasket should last at least a couple of years. Also, do you have any oil leaks or burning oil, otherwise no need to waste money replacing all these parts.
Best is get your mechanic to take a look, gotta fix the right spot right? :)
