Hi bros, interest check on anyone who wants to go into this workshop in JB today or over this weekend... pls pm me... am looking to go in together as a group for added security... thanks!!!
Hi bro, my mechanic said there is some oil leak and will need to change the seals. Kindly pm me the details.
Cheers!!
Hi Aaron, would appreciate it if you could pm me the stockist, repair cost, parts cost and the workshop. I am facing a need to top up oil every 2000km! It's frustrating!
Please save my number.
U can text me before u r going,
I can go along if I am free.
I know the location well.
Via woodlands or Tuas is fine
Cheers!!
Ok, PM u now ....
Ya. PM u too....
White smoke coming out of engine compartment. Know of any workshop near AMK area that work on sunday?
Pls PM me both stockie and Ws tks
I think most workshops are closed on Sunday
Ok, PM u now....
Hi can pm me WS address.
Ok, PM u now....
anyone here the problem comes back after repair?
FYI, my oil level is 100% full after valve seal change since last Oct till now.
Over 1 year now and no more EO loss problem so fix this if you are burning EO through your valve and out through exhaust.
This valve seal is a wear and tear item for E90 so i don't think it will recur until another 3-5 years down the road, hopefully!
afrer the repair last Friday, oil level hit max
this morning cu down to half
monitoring
No problems till now...
your oil level show 2/4, 3/4 or 4/4?
mine showing btw 2/4 and 3/4
If your oil sensor is working properly, and you are not losing EO, the level should not fluctuate.
If you see it fluctuating at different levels each time you check, it's probably time to consider changing your oil level sensor.
Hi, bro Aaron. Pls pm me details of stockist and ws and costs. Tks a lot
Usually is 3/4
The best time to check is 10 mins after starting engine
vt999today
